Switch the coil packs between 1 & 2 see if it moves to cylinder 2. If not pull plug from cylinder 1 after running and use flashlight to see if its wet with fuel or dry. If dry, most likely the injector is bad and not opening. If wet, it's a seal leak on the injector. At least cylinder 1 is easy to get the injector out.
